跳转到主内容
Disassembling of Wahl Lithium Ion Trimmer
你所需要的
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: 步骤 1 中的图像 1,2 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: 步骤 1 中的图像 2,2
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: 步骤 2 中的图像 1,1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: 步骤 3 中的图像 1,2 Disassembling of Wahl Lithium Ion Trimmer: 步骤 3 中的图像 2,2
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
结论
12等其他人完成本指南。
nathan
于10/22/13注册
1,422 声望
创作了6篇指南
4条评论
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - 回复
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - 回复
Thanks…worked well.
Magpie - 回复
You open the clipper by using small flat head on the 4 tabs on the handle
JOSH - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 107
总计 44,941
