跳转到主内容
加入维修社区 - 创建账户
Garmin Vivoactive 是一款内置运动应用程序的 GPS 智能手表,可用于追踪活动、接收通知、计算卡路里和监测睡眠。这款手表同时兼顾了运动和工作环境下的多种功能。
Adjust the Display Brightness
How can adjust my display brightness?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
7个答案
最有帮助的答案
Those online instructions were for vivosmart, not vivoactive, hence the confusion. The vivoactive display gets brighter the more ambient light there is since it primarily relies on reflecting ambient light back out. There is no way to control brightness in that respect. In darker environments, you can turn on the backlight by pressing the power button. The watch really loves being outdoors where it's easier to see the display!
这个答案有帮助吗?
得分 2
添加一条评论
https://www.google.co.uk/url?sa=t&rct=j&... Enjoy :)
这个答案有帮助吗?
得分 0
添加一条评论
When I hold touchscreen I don't get a menu??
这个答案有帮助吗?
得分 0
添加一条评论
Adjust brightness on garmin 295
这个答案有帮助吗?
得分 0
添加一条评论
That's pretty silly because You want to also use the watch a nighttime!
Also be able to see your results weather day or night!
Not a very good feature, it is supposed to show you your results clearly!
这个答案有帮助吗?
得分 0
添加一条评论
I just got my watch yesterday and I also was having a hard time seeing it.
Once I was able to link it to my smart phone ( iPhone ) then after about 15 minutes I could make it barely that an updates was available,
it said this update would take 3 minutes to download.
Once I allowed the update - the normal screen got much brighter
not glow in the dark bright but at least watch tv with the lights down bright
I hope this helps someone else
这个答案有帮助吗?
得分 0
添加一条评论
Select Settings icon. Swipe through to find Backlight. Select Backlight. You will have option for backlight to come on Manual/Notification/Button. I set mine to Button. You can also set the number of seconds. Of course, the light is probably in the top 3 battery draining features of the watch after GPS and the buzzing notification feature, so that’s why it always so dim. I can get two weeks of battery life if I do not use the GPS or notification features.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sholmes8162 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 21
总计 27,988
