跳转到主内容
加入维修社区 - 创建账户
苹果公司较大款的 MacBook Air 笔记本电脑,配备双麦克风及 802.11ac Wi-Fi 连接功能。
MacBook Air SMC problem
Hi all,
I have a problem with my macbook air 6,2.
The first issue was the computer did't turned on.
The SMC reset and regular things did't helped.
I took down the bottom case, and plugged out the battery cable. After this when I plugged in the charger, the computer is turned on immediately.
I took back the case, and restarted the computer, the computer was dead as before.
I ran a hardware diagnostic test and got the PPT001 (battery), PFM001 (SMC) and NDC001 (webcam - this one is weird because I can use the camera).
So right now I can turn on the computer without the bottom case, but the fans are running high etc.
The power adapter led is not lighting, and when I push the shift + ctrl + alt the computer is turned off immediately.
Anyone have an idea what can I do with this SMC issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
Hi,
I have exactly same issue with my Macbook Air 13" 2014.
How do you repair it?
由完成的
First issue was fixed without any intervention. I just waited few days..
The secound issue was the SSD, so I just replaced it. Maybe the first issue was an SSD issue as well.
由完成的
@wntsmk I have the exactly same issue with macbook pro mid 2012 ....what I have to do please help me
由完成的
添加一条评论
3个答案
已选择的解决方案
Yeah it was my first idea. Few days later the computer turned on and worked fine.
But another few days later started to do a weird things, for example restart without any reason. After one of the restart the OS never started again. I checked the SSD with the install system, and haven't seen it, so I ordered a new SSD, and now everything is fine.
Maybe the first issue reason also was the SSD.
这个答案有帮助吗?
得分 0
1条评论:
ok i'm happy your problem is solved.
由完成的
添加一条评论
Guessing right now but, what if you replace the EFI BIOS chip?
这个答案有帮助吗?
得分 0
添加一条评论
Hello, I can recommend a company in Turkey that can repair this malfunction. Prices are reasonable and experts in the repair of the MacBook https://kaptanbilgisayar.com.tr/atasehir...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wntsmk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 7,497
