跳转到主内容
The Isuzu i-Series was manufactured from 2006-2008 alongside the Chevrolet Colorado and the GMC Canyon, all produced from General Motors.
4 个问题 查看全部
Why is my fan belt squeaking
why is my fan belt squeaking
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@tomcat66 fan belts make a squealing noise usually because the belt is slipping on the metal pulley and that is what makes the noise. Fan belts do not squeak for very long. they will eventually snap. Most of the time it is not the belt that squeaks but the tensioner pulley or other bearings on accessories driven by the belt i.e. alternator, power steering pump or similar. Take a close listen (stay away from moving belts since they do snap) replace the belt and check all the bearings.
这个答案有帮助吗?
得分 3
添加一条评论
Does it do it when the engine is accelerated ? If so, the belt is probably slipping. Check the tension and tighten if possible. Alternately, get a product called Belt Dressing from the auto supply. Spray it along the inside of the belt while the engine is running. It will make the belt less slippery and less prone to squeaking.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harold Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 1,920
