跳转到主内容
IBM现代PC的先锋公司。
82 个问题 查看全部
Why do coloured,vertical stripes appear on my R52 Thinkpad screen
Almost 5-7" of the laptop screen gets covered with thin vertical lines on starting the computer.Lines do not appear when adapter is used to connect laptop to another monitor.Is this a 'display' or a LCD problem?Please advise what can be done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
This is LCD screen failure. You'll have to replace the screen.
IBM/Lenovo laptop repair guides.
这个答案有帮助吗?
得分 1
添加一条评论
Those are raster lines and if the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Some panels have issues with the connector that carries the signals. So check your wiring, connections etc. Your video card itself seems to check out since you have no issues with an external monitor. If none of this resolves your issue, follow LaptopRepairGuy's advise and replace the panel. Good Luck
这个答案有帮助吗?
得分 1
添加一条评论
how to repair vertical line in my ibm thinkpad g41
这个答案有帮助吗?
得分 0
1条评论:
saubhagya, are you asking how to fix it? See Laptop Repair guy comment as well as my own. http://tim.id.au/laptops/lenovo/thinkpad... shows you how to approach it. Good luck
完成的
添加一条评论
I had thin red vertical lines on my screen of my T430 Thinkpad. I solved this by disconnecting and blowing air on the connector and reconnecting the screen cable just next to the right hinge
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 5,301
