跳转到主内容
加入维修社区 - 创建账户
轻薄、强大,且具备出色的音质和 Wi-Fi 连接能力,这正是移动办公者所需要的。
HDMI port quit working
I have had this notebook for a year, and have connected as many as two external monitors (using the thunderbolt port and HDMI port) with no problem. I just moved, and now when I set up, with an external monitor using the HDMI port, the notebook does not see it. The control panel only shows the built-in display available. I have checked the cable and the monitor and they are fine. Is it possible my HDMI port failed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
Hold on here a second... Found something that worked for me. Right here, from this site;
Windows 10 HDMI Connection Intel Graphics Issue
Disable and enable the driver, configure project once again. Odd, but I'm happy with this, until HDMI stops working again ;)
这个答案有帮助吗?
得分 2
2条评论:
hi have you solved your problem with the asus ux510ux? I am having black screen with an external monitor
完成的
On the second monitor, open the windows notification thing at bottom, and there should be various display options.
完成的
添加一条评论
Hi,
I am currently fighting with ASUS UX510UX and HDMI issues. Before this, I had UX305, which I gave up believing that its HDMI port had broken suddenly down. I was mistaken.
With UX510UX I soon encoutered the same situation, HDMI ceased to function. This happened with the 1607 update and I rolled it back and this restored HDMI functionality. All was fine fore few weeks and then Win10 updated driver files (you cannot prevent this, unfortunately) and I lost the functionality again.
I was in touch with tech support and they provided me with a installer that overwrote all relevant files and HDMI was restored once again... until today when some kind of a driver update once again took place (you hear that "device connected" sound and screen flickers, then you know that you just had unwated driver update). This time the provided package could not restore HDMI functionality and I am currently trying out reinstalling.
Win10 built-in "Reset" is no good, even with "remove all files" option. Nothing changed and all the bloatware just came back. Now I am performing a factory reinstall with tech support's help.
None of this is likely to help you, but you're not alone and it's unlikely that your hardware is at fault.
You might also be interested that these HDMI issues are occuring with other brands too. From the looks of it, this may be related to all motherboards that have certain Intel chipsets and/or GPU (I believe these are all built into the mobile chip these days). Why this may be of interest is that in Microsoft site some users have reported a success overcoming this issue by locating and buying a "better" HDMI cable. I lack the expertice to speculate if the cables have (or lack) features to cause these kinds of issues (let's imagine, if the driver suddenly relies on some signal/data/other from the monitor before activating...), but this is something I will look into, as I move along with all these attempts to restore HDMI to my laptop.
If you discover something, please let others know - and if you have any influence towards the brand or MS, please try to make them care about this issue :)
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
It's possible that it is your HDMI port failed, but before go on ASUS web site and download the latest video driver for your Zenbook UX303L.
Download it
Install it (without connection to your external display)
Restart your laptop (with your external display connected to your laptop)
The problem can be the driver.
Regards
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mike Ricks 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 33
总计 19,873
