跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Green light on adapter charger but (X) on battery indicator
I have a MacBook 4.1 2.4ghz and there is a Green light on adapter charger but (X) on battery indicator . If I remove the charger the laptop goes off. I was online and looked at a few videos on YouTube about "quick fix" battery not charging on MacBook and I tried the slight pressing on each prongs and that's when the (x) appeared before that it was "battery not charging". Also after the YouTube fix video when the (X) on the indicator replaced the "not charging" msg the power apapter all of a sudden displayed a orange solid light but randomly while connected will switch back to solid green.
Plz Help my ifix team
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Is the X black or red?
完成的
添加一条评论
1个答案
An "x" indicates that the computer does not detect a battery. The computer will stay on when the charger is connected and a green light means the battery is charged or you're running on power from the charger.
All this to say, your battery is likely dead. A new battery should fix the problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonathan Howze 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 74
