跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S II 的更新版,于 2013 年发布,可通过型号 GT-I9105/P 进行识别。
How can I fix my screen?
I droped my phone, actually it's not the first time but it was a hard one, and when i check it there was a black spot on the screen, i knew then that it's broken.
But after a few minutes the spot covered all the screen; though i still can hear the lock screen or when i turn it on so it's still working.
i think i need to change the screen or something like that but i don't know how ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes you can replace the screen but the cost of replacement would probably be more than the phone is worth I see on ebay the going rate is 125 for a replacement and you will need a complete replacement LCD digitizer and glass complete .
http://www.ebay.ca/sch/i.html?_odkw=Sams...
this is a tear down video for your phone
https://www.youtube.com/watch?v=pDkvz9fU...
Everything can be fixed but not everything should be . If you have important data on the phone even with a broken screen you should be able to connect and retrieve the info unless your phone is password locked
Hope this helps
这个答案有帮助吗?
得分 3
1条评论:
thank you so much I really appreciate it.
完成的
添加一条评论
添加你的答案
simo5991 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 330
