跳转到主内容
加入维修社区 - 创建账户
Why won't my computer restart?
I replaced the 256gb SSD in my macbook pro after cloning an image of it.
I set the cloned image onto a 1tb Samsung SSD. I have run it through disk utility and they system appears to be fine - it is just that the machine will only get 3/4 of the way through the boot process?
Running Yosemite.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try starting first in Safe Mode by holding down the Shift key on startup. Since you cloned you probably don't have a repair partition, to check, hold down the option key on start up and see if it is there. If it's there boot from it and run Disk Utilities. Cloning was good years ago and a real time saver but not so today. Better to first format the drive then do an internet installation and use migration assistance to move your apps and data.
这个答案有帮助吗?
得分 5
1条评论:
Thanks for this - ultimately, this is what I ended up doing. I have an image of my system and I will be making decent regular back ups in the future.
完成的
添加一条评论
添加你的答案
Gregory Machin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 153
