跳转到主内容
加入维修社区 - 创建账户
型号 M6497 或 A1005 / 500、600、700、800 或 900 MHz G3 处理器
Graphics Issue
I am having a Graphics issue with an iBook G3, the graphics keeps causing the Screen to either go blank or go White with 2 Blue Strips down it, Please reply with a fix and possible a pic for demonstration
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
unfortunately you are probably experiencing a common issue with this series - the graphics processor either fails or its solder joints to the logic board become loose.
some have had success using non-conductive material (folder paper square, etc) to create a shim between the chip and the case, causing force and pressure to hold the chip stable. others have been able to get the chip solder reflowed.
see these existing answers:
Why does my iBook randomly freeze?
Display Screen stays black, but computer still works good
这个答案有帮助吗?
得分 1
添加一条评论
You could check this out.
http://cgi.ebay.com/iBook-G3-Logic-Board...
这个答案有帮助吗?
得分 0
添加一条评论
Thanks everyone
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Darth Seleyus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,775
