跳转到主内容
加入维修社区 - 创建账户
2014 年发布的 RCA 7 英寸平板电脑(型号 RCT6773W22)的维修与故障排除指南。
Tablet won't turn on
Tablet will not turn on. When power button pressed, screen shows a darkly whiteish screen. Nothing happens. We have even pressed resetbutton a few times. Still nothung
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 39
14条评论
my RCA computer tablet just quit working it went off
由完成的
Where can I send this to my tablet won't turn on and I've tried the volume and start butten
由完成的
My tablet is not working push the volume button and the on and off button it never worked
由完成的
mine cant still work, :(, I tried everythin
由完成的
My tablet is in fastboot mode and I'm not sure how it ended up this way. I have followed all of the suggestions on what to do but nothing works
Also it doesn't seem to hold charge
Do these two issues have anything to do with the other? Thanks for any help!!! I'm very curious as to what the problem is
由完成的
显示更多的9条评论
添加一条评论
9个答案
已选择的解决方案
Sandy, read through a few forums on RCA tablet won't turn on, most of them suggest, push the power and volume up button down at the same time for 10-20 seconds. Try this once or twice. If it does not turn on wait a few minutes and try holding down power and volume button again. They also state to try charging it through your computer, as some times the USB will some how kick start the charging again in case of faulty tablet charger. Check and read the links attached for more info. on how to power up your tablet.
Check the attached links,instruction and guides, Good luck.
http://www.tomsguide.com/forum/id-248283...
https://www.youtube.com/watch?v=K1zOqKR8...
https://www.youtube.com/watch?v=m_SGKMsN...
这个答案有帮助吗?
得分 22
19条评论:
my tablet still inst working i tryed everything
由完成的
Your a genius.
由完成的
My tablet isn’t turning on and I’ve pressed down the power and volume up button at the same time and I even charged it. It isn’t turning on
由完成的
My tablet is not coming on at all what should I do
由完成的
Yeah mine did the same easy fix..... Throw the ##&&% away
由完成的
显示更多的14条评论
添加一条评论
There is a reset hole on back of tablet next to the SD card slot. Use a paperclip to reset ( you should feel a slight click) then hold power button and voila!!!
这个答案有帮助吗?
得分 5
3条评论:
Thanks!!!! Merci Beaucoup!
由完成的
the clip didn't fit
由完成的
Try using a SIM removal tool
由完成的
添加一条评论
I don’t know what I did that caused it to come on because I tried several of the suggestions here…like pressing the on and sound at the same time and reset.. but when it came on I think I was pressing the reset and on at the same time. I was about to throw it away before I found these postings. Now I have to put the little screws back in it as I had torn it apart to see if something was loose or broken
这个答案有帮助吗?
得分 1
添加一条评论
My wife’s RCA tablet had been dropped and would not “turn on”. I placed it on a different charger to make sure the charger wasn’t defective and while charging, I heard a chime from the tablet so I then I felt it had to be something with the display. Upon opening the unit, I found that the ribbon cable that connects the primary board to the display had been pulled from its socket. The cable was secured with a piece of tape on the battery and when dropped, the weight of the battery pulled the ribbon cable from its socket. Reinserted cable and all is well.
这个答案有帮助吗?
得分 0
1条评论:
How did you get it open?
由完成的
添加一条评论
The model I have doesnt have the volume buttons on it, they are all on screen, so what do I do now
这个答案有帮助吗?
得分 0
1条评论:
Same here, but if you look on the back right below your on/off button, you will see a little tab that has 2 dots, one bigger than the other, that is your volume button. Thats where mine is, try and see if yours is there, too. Big dot is up, small is down. Hope this helps.
由完成的
添加一条评论
Thankfully, i followed the instruction by holding down the power button and the volume button at the same time for the 10 -20 seconds. First attempt nothing but on the second attempt it came on and is working. Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Took back off after I mashed reset button and all. I go to pull charger out and it flashed. It doesn't it when I try pull it out??
这个答案有帮助吗?
得分 0
1条评论:
Can you unplug the battery and plug it back in?
由完成的
添加一条评论
Hello, I have tried almost everything I could find on YouTube to get my RCA Viking Pro 10 to work, and at 1st it worked when I unplugged the battery and plugged it back in, but then after a week of leaving it alone it just stopped working completely, the blue light to indicate that the charger is turning on but it should be flashing off and on, and it isn’t doing that, could this be a battery issue?
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I have the RCA Viking pro tablet and it stopped working/turning on about a week ago and the blue light that indicates it’s charging stopped coming on. I tried everything to get it to come on and nothing worked so I got frustrated and left it alone. Then tonight I noticed the blue light was on indicating it was charging and I opened it and it was on but stuck on the Viking Pro screen like it was in a reboot loop or something, so I hit the reset button and it turned off and back on did the same thing for about ten minutes. So I hit the reset again and this time it’s back to not turning on and the charging light won’t come on again! Someone please help! It’s driving me insane! Is it a bad battery or what?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sandymf64 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 45
总计 71,452
