跳转到主内容
加入维修社区 - 创建账户
Cuisinart Griddler GR-4N a five-in-one kitchen appliance to be used as a contact grill, panini press, full grill, full griddle or half griddle .
Why doesn't the indication light turn on?
The indication light has stopped turning on even when the device is on and the cooking surfaces are in use. Does this mean the heating temperatures are affected or is it just the light which is an issue and how do I address this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The indication light on the cooking knob does not turn green until desired temperature is reached. If light does not turn on there is a problem with the LED light, either the light needs to be replaced or simply internally reattached. Follow link to fix LED Cuisinart Griddler GR-4N Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
It is neither a light or a connection
It controlled by the board on the far left side. You have temp sensor in the black metal spring in the middle of the unit. That sends a signal to the board
There is a small ic that controls a relay that is at the end of the pc board
If you are able to heat up the solder connections that may resolve the issue
Good luck if not as they don't sell this important part
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kayla Londono 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 42
总计 4,992
