跳转到主内容
加入维修社区 - 创建账户
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
LCD Screen Replacement - 2 Wire?
Hi, I have a A1181 Black Macbook 13" Early 2008.
The screen was damaged and I am looking for a replacement.
Many of the parts I see online say to make sure my computer is 2 wire vs 3.
How do I know this without opening the computer up? I want to wait for the part to do that.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Here is the IFIXIT guide you'll need to follow: MacBook Core 2 Duo Display Replacement.
If you review Step32 you'll see the difference between the Two Vs Three wire versions. Basically its the Antennas. One model has the Bluetooth as a separate part and antenna which you can see in Step21 in the guide.
Popping off the upper case to do the inspection is quite easy! I would do that so you get the correct display assembly.
这个答案有帮助吗?
得分 3
2条评论:
Thank you. Is there any other way for me to know before purchasing and not opening my laptop up?
Can I look up by my serial number to see if I have a MacBook Core 2 Duo Santa Rosa/Penryn with two antenna cables?
完成的
Try the EveryMac lookup. See if you have the Santa Rosa version or not. I still think popping a few screws is more definitive. It's really not that hard to do.
完成的
添加一条评论
添加你的答案
Apollo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 129
