跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
iPod won't register on computer or turn on past Apple screen
My Ipod Classic 160 gb is failing all of a sudden. Won't respond at all when not connected to power. When connected, iPod flashes dim Apple screen over and over. If I try restoring it (center button+menu button hold), the screen will light up with the Apple logo but then constantly restarts that. Won't show up on a computer. Can't hear hard drive turning. Is the whole hard drive failing or just the logic board? Also does the fact that it won't respond when not connected to power point to battery issues, or could that also be a logic board issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@cdhoover that's a tough one. I'd start with a new battery and get a Zif-to-USB adapter. Replace the battery and check the hard drive on your computer by using the adapter. That way you can rule it out as the culprit. Of course you also want to make sure that you use a good cable and that your dock connector is clean, clear of lint and has no broken, bend or corroded pins.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Caitlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 122
