跳转到主内容
加入维修社区 - 创建账户
土豆先生是一款美国玩具,由一个塑料土豆模型组成,可以用各种可以固定在主体上的塑料部件进行装饰。
Grinding sound won't move
My Toy Story Collection talking mr potato won't move his legs like it's supposed to and is making a grinding sound how to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Please let me know how you fixed it ???
完成的
添加一条评论
6个答案
最有帮助的答案
  1. The Real Mr. Potato has no moving Parts. He doesn't move either, at least on his own.
  1. Open up Mr. Potato's back and dump out the innards.
# Have fun!
这个答案有帮助吗?
得分 1
添加一条评论
Gearbox gear repair.
It seems to be a fundamental problem for the product.
All the problematic products are the same gear problem.
The two gears in question must be repaired by opening the gearbox.
It would be easy to get the same gear, but...
A gear is cracked.
The thickness of the steel pipe in the middle is larger than the gear hole, resulting in a crack.
Secure the cracked gear with glue and expand the hole.
Grind steel pipes to make the hunger thin.
https://youtu.be/4QJFvA5n3gs
업데이트 (2019년 10월 23일)
The cracked side of the gear needs to be cut and glued. This ensures a constant gap between the teeth.
The gears were first disconnected and then polished the bumpy part of the metal pin.Cut off the cracked part a little and fix it with a force adhesive. Apply a little glue to the metal pins and fasten them with the gears.
这个答案有帮助吗?
得分 1
6条评论:
Do you have a diagram of how the gears fit together?
完成的
@weirdalfan1 No, i have not. Cut off the cracked part of the gear. Because it is to fit each gap in the gears. This is important.
完成的
Hi there please can you help me. My mr potato head is also broken. He talks but does not wobble. Could you maybe do a step for step guide with photos on how to fix him..... im part of a toy story collection group on facebook and it seems to be a regular problem. If you could do that im sure you would help allot of people we all struggling.please please pretty please. I love my mr potato head and so badly want to fix him i have spent days trying to figure it out but havnt come right. :(
完成的
The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
完成的
@Antoinette Botha The repaired product was not mine. The repair process was complicated, so I didn't take many picturesI'll organize and let you know the photos I took at the time. If you ever visit Korea, I will help you.
完成的
显示更多的1条评论
添加一条评论
Step-by-Step Fix
  1. Disassembly: Document each component’s position and assembly order with photos.
  2. Gear replacement: Swap the damaged gears with precision-matched custom gears.
  3. Lubrication: Apply silicone-based grease to all moving parts.
  4. Reassembly: Reverse the disassembly sequence strictly.
Simply using glue to repair a broken gear often doesn’t work. Initially, I tried that approach too, but the result was that it still jammed. Because the gears in Mr. Potato Head are very precision-engineered, I ended up repairing it successfully by replacing the gears with custom-made ones
这个答案有帮助吗?
得分 1
添加一条评论
Hi hi, i wanted to find out did you manage to fix your mr potato head? Mine is doing the same thing…he speaks but no longer wobbles. Please help. It must be the gears … i glued the 2 cracked gears but when i put him back together he still doesnt work.
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
Hello, thank you very much for your help, but the problem is that when I opened the gearbox one of them came loose and I don't know where to put it. I have included photographs with the gear
这个答案有帮助吗?
得分 0
1条评论:
I don't see the picture you sent. Maybe you should check—there's no gear image.
完成的
添加一条评论
I have same problem and wonder where you obtained the replacement gears
这个答案有帮助吗?
得分 0
1条评论:
I modified some but on Amazon there is an assortment of platic gears for toys. There are like 75 in a pack for under 8 USD
完成的
添加一条评论
添加你的答案
Dillon Bieber 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 61
总计 3,010
