跳转到主内容
加入维修社区 - 创建账户
HP Officejet 6500 是一款彩色多功能一体机,发布于 2003 年。型号:CB815A#B1H。
not picking up paper
it's not picking up the paper to print. Mine is a HP inkjet 6500A. The answers I found in this page was for Canon printer. What should I do? If I can't fix it myself, is there a HP inkjet printer repair location in San Antonio?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
there is a gear that breaks that drives the paper pickup rollers. the gear actually splits. i have glued it on the shaft and works fine. Its just a really big messy job
完成的
添加一条评论
2个答案
已选择的解决方案
Estimado yo tambien tenia el mismo problema, la falla era en uno de los engranajes de el sistema de alimentacion de papel , lo pegue y se soluciono . Te puedo mandar fotos del engranaje
Espero te pueda servir
https://drive.google.com/open?id=0B4Wwlw...
en la imagen puse un espejo desde la bandeja para poder mostrar el engranaje .
这个答案有帮助吗?
得分 3
2条评论:
Explica mejor como es que lo pegaste y como lograste llegar hasta ese engranaje
完成的
Here is a translation, thx to Google translate
Dear I also had the same problem, the fault was in one of the gears of the paper feed system, paste it and solve. Can I send you photos of the gear?
I hope I can serve you
完成的
添加一条评论
I glued it and it lasted 3 prints. I believe the heavy photo paper took a toll. I am now looking for a top feeder. Any suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Genx Ed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 2,868
