跳转到主内容
加入维修社区 - 创建账户
XFX 680 芯片组的精简版,成本更低。
RAID 0 gone bad.
any ideas to get a raid 0 array working again? the drives are fine and all the data is on them, but raid doesn't want to recognize them. someone suggested rtools, but a demo version only lets you recover 64kb files. key? other options?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
did I mention this is for an XFX board?
read: running Windows 7.
完成的
添加一条评论
1个答案
已选择的解决方案
If the RAID set is broken, yet you can read the data, your best option is to copy off what you can/need.
The only way I know to get a broken RAID 0 set back working is to set it up as new - which means the existing data is going to be erased.
RAID 0 is all about speed and performance - there is NO data redundancy... Depending on how your RAID controller and RAID 0 set was created, you may only lose files split across the drives (JBOD mode). If your RAID 0 was in Striped mode, you will probably need pay for something like rtools.
这个答案有帮助吗?
得分 1
3条评论:
that's what I figured, I'm trying to decide if rtools is worth it because I don't actually remember what's on them. If I knew, I'd be able to decide. Oh you, impasse!
完成的
完成的
R-Studio is a great thing. You will certainly be able to use it for other things beside this problem.
完成的
添加一条评论
添加你的答案
tabormeister 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 4,823
