跳转到主内容
加入维修社区 - 创建账户
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
Is my code wrong on my javascript
My code must be wrong because i keep getting an error that says "Illegally formed XML syntax. (line 5, file "Code")"
Heres my code
<FORM>
<INPUT TYPE="button"
VALUE="click here to add a game"
onClick="parent.location='mailto:1637206@student.ucps.k12.nc.us?su... would like to add a game to the website'">
</FORM>
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Andrew
So ,i tried yout code, and it did work, but i did see some syntax issues.
In most cases if you make one or two small mistakes in HTML, the browser 'fixes' it for you.
The 'mistakes' i saw are:
1. The button doesnt termintate. For each HTML element, it needs to terminate, ie. open, and close.
There are 2 ways to do this.
<tag id="tag1">somestuff</tag> (open and close )
<tag id="tag2" /> (self closing)
You seem to close the FORM element with a "</FORM>" at the bottom, but you never self closed the "INPUT" element.
2. It might not be the cause, but it should be addressed, is that you dont have any HTML tags either.
All html documents need to start and end with <html>...</html>
And should also contain a header, and body elements.
Here is your code, with my small modifications:
<html>
<head>
</head>
<body>
<FORM>
onClick="parent.location='mailto:1637206@student.ucps.k12.nc.us?su... would like to add a game to the website'" />
</FORM>
</body>
</html>
I hope this helps
Ian
PS, For more info, try using the W3Schools website: http://www.w3schools.com/html/
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Andrew Goodson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 309
