跳转到主内容
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 个问题 查看全部
Damaged Chip on MacBook Pro ( A1502, Mid-2014, Retina, 13")
Hello all,
I was recently cleaning my motherboard (820-3476-a) from water damage using isopropyl alcohol and an antistatic brush and damaged a chip. It is completely gone - like can't even find it.
TL;DR: Please identify the grey chip missing in my attached photo (white arrow pointing to missing chip).
After hours of research, I ended up with a boardview and schematic, but the schematic is not easily understood and my .BRD file will not open in any programs that were suggested. Now, I found both of these files separately on random forums, but many people had responded an verified that the boardview file worked.
So, if somebody can please help. I can send you the schematic and .brd. I just need the chip model number to send to a friend who does micro-soldering.
Thanks.
Here is the .brd that I'm having trouble with: https://drive.google.com/file/d/0BxX337h...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@skinnys this answer is not to diagnose your board but just to identify the component. That is L7870 which is a 2.2UH 2A 0.155ohm inductor in a 2512 package. Remember there is a reason why it did blow up. check for short circuits etc. Looks like Mouser.com as well as Digikey.com carry those.
这个答案有帮助吗?
得分 4
7条评论:
Thanks! This is the closest item that I could find that matches your description on Digikey (note, this is my first time to search for this type of product):
http://www.digikey.com/product-search/en...
完成的
looks like it should work.
完成的
Great, so just order that and have it soldered on? Also, I can't seem to buy less than 2,000 when I choose the quantity to add to the cart.
完成的
Let me see what I can find....
完成的
Any news on that chip?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
scott randolph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,595
