跳转到主内容
加入维修社区 - 创建账户
1999 年至 2004 年间生产的第二代北美版 Honda Odyssey 的指南和维修信息。
2004 honda odessey problem.
my 2004 honda odyssey cuts out while driving
all of the dash lights come on and the engine shuts off
start the car up again and runs fine for awhile. A few days later it does it again.
Also the green key light will stay on after each occurance
A very intermittent problem.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
My radio need code it not working
由完成的
Did you find out what was causing the issue?
由完成的
添加一条评论
1个答案
已选择的解决方案
I have seen this before and it has to do with the chip the car needs to read in the key . There is an rdf reader in the steering column that is shorting out and setting off the security to kill the car. it blanks out when hitting a bump and the chip in the key looses its signal and all of a sudden the security kicks in and kills the car. Something to check . Do you have more than one key for the van ? If so try a different key and see if it makes a difference. Hope this helps
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Taller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 2,279
