跳转到主内容
加入维修社区 - 创建账户
Verizon 版 Samsung Galaxy Tab 4 8.0(型号 SM-T337V,也称为 Samsung SM-T335)于 2014 年 4 月 1 日发布。这款 8 英寸平板电脑搭载 1.2 GHz 四核处理器,具有多窗口功能,并配备 300 万像素摄像头。
Digitizer cable issues ugh
I have a Galaxy Tab 4 8 inch from T-Mobile. It works great but recently I have had trouble with the touch screen. I tried a factory reset and the problem still persisted. The touch screen works for the most part but the top 5% of the screen just doesn't respond to touch. I installed a touch screen tester where you draw across the screen and it is definitely the top 5% of the screen below the Samsung logo. I opened the case with a spudger and the screen cable was loose. So I pushed it back down but it doesn't lock in any way. It definitely feels secure but there is no click feeling when you push it down it kind of just sits there. The problem is it comes loose again every day or two. I tried taping it down but it still happens somehow. It also seems like the connector cannot be pushed all the way down because when it is the touch screen acts weird. There will be phantom touches happening when I'm not even touching the screen and parts of the screen work very sporadically. Does anyone have a clue how to fix this. Is there like a foam piece I can buy to keep it pushed down all the time. Or could this be the behavior of the digitizer and going bad? I don't want to have to replace the digitizer because I am horrible at separating the digitizer from the LCD and don't want to have to spend between 50 and $80 on the whole LCD assembly. Has anyone else experienced this specific problem? Any suggestions? Should I just suck it up and try to send it into Samsung? I only got it 3 months ago so it should still be under under warranty I think. Did I void my warranty by opening it? Any help would be appreciated thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Opening your tablet while it is still under warranty definitely voids the warranty as far as the manufacturer is concerned.
As regards to your cable/connector problem. If the 'locking bar' seems to be not functioning properly, perhaps you could try the following.
Tape down the connector as before and ensure that the touchscreen is working. Then apply small 'dob(s)' of neutral cure silicon sealant (available at hardware stores) between the cable, the connector and the systemboard (or any other suitable point) to hold everything in place. Keep the tape in place to hold it in position while waiting for the silicon to 'cure'. (read the manufacturer's guidelines on the product for how long this takes). Neutral cure silicon is good because it is non conducting and is good for a long time. Once it is set you can remove the tape. Then test that it is still working correctly.
Do not get over enthusiastic with the silicon. Before it sets it is very sticky and messy and hard to remove. It may be easier to apply it with a small applicator (a long matchstick perhaps). Practice first on a piece of scrap material, so that you do a neat job.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Donald Kirchner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 1,388
