Why won't my battery charge?
My battery will not charge even when it is hooked up to the charger.
If your battery won’t charge, first look to see if the light is flashing on the charger you plug into the wall. If the light is not flashing then there may be a blown fuse in the battery charger which can be replaced. If it is not a blown fuse it may just be a defective battery or an old battery since batteries over a period of time may not be able to hold charge as well as when you first got them. So in that case I recommend buying a new charger if you can not replace the fuse on your drill.
这个答案有帮助吗?
A little confusing (no pun) You suggest buying a new charger if the batteries are defective???
Confusing to say the least, all of my dewalt batteries are approx 24 months old and same goes for my chargers. I get one flash of the red light then nothing...none of my batteries should be depleted and the chargers should still be okay too
I have this also. Bought new charger, and still same problem
Well, I fixed a lot of Dewalt and Milwaukee batteries.
These Lithium Batteries are dangerous, they might cause a fire so inside each battery there is a protective circuit to prevent the battery from causing a fire.
These cells go bad in three different ways. cell(s) get short, they get open, or they fall behind the rest of the cells.
Inside these type of batteries there is a circuit called balancing cells, it monitor each h cell and apply the charge that each cell needs. When it sense one cell is different and can’t be balanced by the circuit it indicate that the battery is defective.
So in your case you have short cell(s) inside the battery and need someone to fix it for you or buy new one.
My advice is to keep it out of the tool and place it on the charger every two weeks to keep the battery functional.
If anyone have question or clarification you can email me at wkassem14@gmail.com
I know this Answer may be a bit delayed but I had exactly the same issue after using my Dewalt 18v lithium ion battery to run Christmas lights. The battery got totally depleted and when trying to charge it all that would happen is one flash of the charger then absolutely nothing. No indication of life while pressing the indicator button on the battery either. Apparently these batteries can go into sleep mode if totally depleted.
To cure the issue I got a fully charged identical battery and connect wires to the outer + and - slots. I then connected the dead battery to the other end of the wires in the same slots…..make sure + goes to + and - goes to - . I found I only had to do this for a few seconds then Disconnected all wires. On pressing the indicator button on the dead battery I then got a faint flash…..next I place the battery in the charger and it started to charge as normal and after an hr it was fully charged and worked as normal.
这个答案有帮助吗?
I have had this a few times patience is the answer put flat battery in charger and leave for about an hour until red light comes on without flashing then remove battery and plug back in should charge fully then
These days, it’s due to tired original NiCd batteries. I have a DC970, and both of my batteries are done. However, I recommend not matching what you have or buying knockoffs: scraping the NiCd setup and replacing the problematic NiCd system is the better play. Sometimes, the old NiCd packs were recovered via a jump, but they never lasted because the packs are toast once it's THAT bad. You can usually wait for a sale on the midrange brushless 20V drill to come up with 2 batteries and end up with the batteries at a lower cost, albeit 1.5Ah or 2Ah, depending on the deal. The original NiCds were 1.2Ah at the base, so 1.5Ah is still an upgrade.
If you need them NOW, try to jump them. Sometimes, they can be saved for one or two final runs, but don't expect them to take that kind of abuse much longer before completely dying out. They don't take abuse like that well after 11+ years; that's in addition to the charger zapping them to drain them quickly, which was done to kill the NiCd memory effect problem. For all intents and purposes, due to the risk of permanent damage on frail batteries, it's better to treat the use of the jumped packs as their final run.
When they go bad and do their last job, I usually recommend that these older DeWalts get the DCA1820 adapter and the 20V batteries; 1.5Ah or 2Ah works as both are upgrades from the stock 1.2Ah DeWalt shipped back then in the non-XR configuration. AND they lose the memory effect problem. However, the rub is this is the dream setup (especially if you can buy a drill with TWO pack-in batteries), and it's more cost-effective then bare batteries alone*. If you want to reduce your guilt about buying a tool for batteries, look for a reconditioned drill from a shop like CPO Outlet; you will probably get batteries with some wear, but it's not as wasteful. The kits with dual batteries always go on sale, so ¯\_(ツ)_/¯. I'd take it if I didn't own XR tools and 5Ah batteries from battery sales without a second thought.
DO NOT BUY BRUSHED TOOLS; BUY BRUSHLESS ONLY. The brushless stuff lasts a lot longer and has far more power. Brushed is old news outside of previously owned tools. Your best bet to buy the DCA1820 is piecemeal from Home Depot or Amazon.
DeWalt also sells the parts needed as a kit, but it is not truly as cost-effective UNLESS IT IS ON SALE (DCA2203C). If the tool can't be converted (which is rare), consider it a dead tool and buy a 20V equivalent (yes, I have two of the hand saws because of the free tool deals, and one of them is an "XR" tool (brushless).
I have this info because I own a NiCd drill where I lost both batteries to wear and tear once and for all, and the only feasible way to put it in service I saw was to swap to LiOn this way, so I've done the research to make conversion economical.
The advantage of the DCA2203C kit is that the packs are safe for 100% of the tool lineup, even the infamous DC970, which is not able to use the premium batteries. However, these packs are weak compared to others. The MASSIVE DOWNSIDE is that it is never discounted. Because of that, the more economical conversion comes when you buy a mid-tier Brushless drill with two batteries in the package and then source out the DCA1820 separately.
For the green ones who don't want to buy extra items but need new batteries: This is (probably) a bit more wasteful upfront because you also purchased a tool and charger, especially if you have them on hand (as I do with the XR tools). However, the math still tells me buying a lower-end brushless drill kit on sale is the cheapest way to put my DC970 in service again.
That said, in SOME cases there may be a slight price differential in favor of the DCA2203C kit; but this is usually only +/- ~$40-50 if it's all you can find. Either way even with the "waste", my opinion is you might as well buy the drill with 2 batteries, especially when they get put on same. These NiCd tools are brushed, and brushed tools have a lifespan based on the wear level on the brushes. This is generally not the case given how often DeWalt subsidizes their tools so the hardware stores can use them as a "loss leader" to get you into the store for little things you probably needed anyway.
*I picked up some Powerstack batteries and these may be a nice candidate, but the downside is you need to own the charger otherwise this makes no sense as a single 1.7Ah Powerstack (safe for all tools) is $120. No thanks, too expensive :/... Buy the drill with the 1.5Ah or 2Ah packs and adapt it. If you own some of these, you own all you need short of the adapter if you need to buy the parts.
While I still have my NiCd charger in storage, it's a doormat until I can get a deal on a 2-battery drill bundle. DeWalt discontinued the NiCd batteries, likely due to cell availability issues (either way, GOOD RIDDANCE). But that's fine because the downsides of keeping the NiCd packs in service are worse than upgrading to Lion and buying new tools when there's an official fix.
这个答案有帮助吗?
hi nick, hope you have a great day
Found a site that answers the question:
这个答案有帮助吗?
Thanks David, this was very helpful!
过去 24 小时: 16
过去 7 天: 69
过去 30 天: 363
总计 53,566
2条评论
Pillerin dirençleri bitmiştir
由 SELAMİ DEMİREZEN 完成的
I unfortunately have the discontinued 40 volt setup and have 2 dead batteries. They don’t even have 1 bar. I bought what I was told was a new battery and it would only charge to one bar. I’m going crazy. Any help would be make me most greatful as I have leaf blowers and chain saws I can use anymore.
由 EricsMuscleCars 完成的
