跳转到主内容
加入维修社区 - 创建账户
500 万像素相机,配备 12 倍光学图像稳定变焦功能。于 2005 年 6 月发布。
Battery door wont open
Any idea how to get it open seems to be stuck
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Mine wont close. So the camera don not fonction anymore...
由完成的
I have a similar opposit problem. My camera's battery/door wont closed, so the camera do not work at all since. What should i do? I love this camera: Canon PC1310
由完成的
添加一条评论
2个答案
已选择的解决方案
To open the battery door on this camera
  1. Hold the camera upside down with the lens towards you
  2. Slide the LOCK switch to the right and hold
  3. Slide the battery door towards the front of the camera as far as it will go
  4. Flip the battery door open
If the lock switch won't move, it may be stuck due to dirt, or corrosion inside the battery compartment. A drop or two (not more!) of WD-40 might help in getting it moving again.
If the lock switch moves but the battery cover won't, either the locking mechanism is broken and stuck, or the battery cover itself is stuck, the latter is likely due to corrosion in the battery compartment. Apply a few drops of WD-40 around the seam of the battery door, wait a while and see if the battery door will move. Repeat the operation if necessary. Don't force anything. If the battery door still refuses to budge, take the camera in for servicing. Same thing holds if the battery door will open but there's abundant corrosion due to batteries having leaked.
If you succeed in opening the battery door with the aid of WD-40, remove any traces of the latter with a cotton swab and some alcohol: the solvents in the WD-40 may attack the camera's finish.
这个答案有帮助吗?
得分 9
4条评论:
Thanks soooo much I will give that a try! What would the world be like with Duct Tape and WD-40? :))
由完成的
Believe it or not, I seldom use either. Instead, I use Kontakt 70 and gaffer tape, but these are more difficult to get hold of for non-specialist. :)
由完成的
I got a rubber finger tip from office depot. Cut and Sewed on strap. Great!
由完成的
Thank you so much. I was struggling and you have saved my time and temper.
由完成的
添加一条评论
Finger tip from Office Store. Sewed on. Works great.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark Herman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 48
总计 30,626
