perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
这个答案有帮助吗?
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
这个答案有帮助吗?
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
这个答案有帮助吗?
You dont want to walk on any glass floors with those shoes
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 92
总计 2,945
1条评论
I sprayed silicone on the boot material
由 michelle.jarvid 完成的
