跳转到主内容
Guides for shoe repair and maintenance, keep your pair of foot apparel in pristine condition.
36 个问题 查看全部
perserving heel and soul using silicone
New boots showing wear after being worn 4 times. Would a coat of silicone protect against wear?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I sprayed silicone on the boot material
完成的
添加一条评论
4个答案
最有帮助的答案
You may be able to use silicone to rebuild your worn outsole, though the success of this repair might depend on the product you are intending to use and the type of material your outsole is made out of (leather, rubber, etc.).
A tried-and-true product specifically used for shoe repair is Shoe Goo. Here are two guides to help you complete the repair:
Hope this helps!
Shoe图片
指南
How To Fix a Hole in the Sole of a Shoe
难度:
中等
30 minutes
Shoe图片
指南
如何修复鞋底上的洞
难度:
非常容易
15 minutes
这个答案有帮助吗?
得分 4
添加一条评论
If these are leather you can use several things:
These are made of hard plastic:
http://www.amazon.com/Traveler-Plates-Na...
These are nylon:
http://www.ebay.com/itm/10-pr-Guard-Heel...
These are metal:
http://www.ebay.com/itm/DIY-metal-BIKER-...
These are hob nails, worked well for the German army:
http://www.najecki.com/repro/shoes/Hobna...
这个答案有帮助吗?
得分 4
添加一条评论
Here's something you might try. A bit costly I admit, but your shoes will wear down the pavement instead of the other way round ;)
(sorry, couldn't resist)
这个答案有帮助吗?
得分 2
2条评论:
You dont want to walk on any glass floors with those shoes
完成的
"In these shoes?? Let's do it!!"
https://youtu.be/9qoivS9nbrc
完成的
添加一条评论
我不知道!我不知道!我不知道!我不知道!我不知道!我不知道00!
这个答案有帮助吗?
得分 0
1条评论:
At least you know you dont know
完成的
添加一条评论
添加你的答案
elisabeth 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 55
总计 3,915
