跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Camera 2 是智能相机的第二代产品,可以在拍照后立即上传照片。这款相机型号为 EK-GC200ZWAXAR,搭载 Android JellyBean 4.3 系统。
Zoom is not responsive
When turning the zoom dial, the camera itself will not zoom. Any way to fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Yes, you can open the camera up and check the connections. If they are connected well and all other parts are working, you probably need a new zoom assembly, which has the power button as well. Alternatively you can zoom with your fingers on screen by moving them toward each other or away from each other. If the camera does not zoom by either method (I.E. the dial by the power button, nor the touch screen input), then check the lens apparatus itself. There may be dirt or something, or a loose cable somewhere. If everything looks good it might be broken and need to be replaced. Hope this helps Sophia!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Sofia Isern 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 44
总计 700
