跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Battery % doesn't change. Need help to identify Components!
I have a very strange fault with a couple of iPhones. I regularly replace the rear housing of iPhones, I am very careful with the replacement of screws (correct screws in correct positions and not tightened excessively). I have successfully completed this over 50 times and consider myself fairly competent in doing so.
However, I have come across something which is very bizarre and has happened on three separate occasions now. Once I turn the iPhone on to test it the phone will blue screen and restart itself two or three times at random. Once this has happened the phone will function perfectly except for the battery % display will not change. Obviously this causes the user to not be able to track when it needs charging. The phone will run out of battery and the process will happen again.
It must be something I am doing to the phone, I am not overly fussed on finding a fix. Just a reason why this is occurring and how I can prevent it happening again in the future!.
Thanks in advance,
Update (03/31/2016)
I have done some more research and believe that the issue may be an "FL 11 capacitor" could anyone confirm this and give me some info about what it does exactly and where I can source one to try and fix the issue?
Update (04/01/2016)
So I have had a look at the logic Board under a microscope and have found that some capacitors have been knocked off when removing the battery. I think the one on the far left is a "FL 11 inductor" but I am not sure what the other two are. Could someone tell me what they are?
Good Logic Board :
Damaged Logic Board :
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Hi, I had not seen that. Have had a look over and has confirmed my theory that I may have accidentally damaged the"FL11 is a 120ohm 210mA inductor". If someone could confirm this it would be ideal.
完成的
添加一条评论
2个答案
已选择的解决方案
Chris from right to left:
FL11 is a 120ohm 210mA inductor in a 1005 package
C279 is a 56pf 16V 5% capacitor in a 1005 package
C23 is a 56pf 16V 5% capacitor in a 1005 package as well
这个答案有帮助吗?
得分 4
4条评论:
Hi I'm Felipe Zuluaga and I go to Tray to speak in english... i have exactly too problem but i have a the boar that change the components, trying to change I lost C23 and FL11, can remplace the component this with other capacitor an inductor?
完成的
Felipe Zuluaga why not replace it with the right components? You do want to change a capcitor for a capacitor and inductor for inductor. You are not thinking about changing a capacitor for an inductor?
完成的
The capacitor does the opposite of what an inductor does. If you do that the battery circuit will not work.
完成的
I go to change the components, but I have a problem try to soldering. What kind should I use Soldering, wire or liquid? And what kind of point of the soldering iron?
完成的
添加一条评论
Hi, I have almost the same problem, but the FL11’s pad is missing. How can I fix this? Can you tell me which component is connected to the pad? Thank you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 1,285
