跳转到主内容
加入维修社区 - 创建账户
Inspiron 15-3521 配有可选触摸屏功能,并配备 15.6 英寸显示屏。这款笔记本电脑还拥有哑光表面,以及带有数字小键盘的键盘。
Why USB ports are not working
the USB is not working I tried all the Dell diagnostic and it is failed.
I tried to rest and still not working.
BIOS is good.
I need to get it repaired but dont know which chip is responsible as both usb ports are not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
1个答案
最有帮助的答案
Most common case is the burn fuses of the USB port.
A) Check the fuses – if available
B) You can check the power rails and it should be 5V – if you get >4.0V check the main PMU (Power management unit)
C) 3rd Gen Intel core CPU works with PCH (Platform Controller Hub), the PCH is the responsible chip for USB functioning
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lulujaimearredondo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 1,844
