跳转到主内容
加入维修社区 - 创建账户
Not Firing Or Turing On.
I have one of the Zeus Rival guns and for some reason its not firing at all. I have the ridiculous 6 C batteries in right but still nothing. I have also made sure to turn off the safety. I am going to have to open her up soon if I am unable to find a resolution. If anybody has any ideas feel free to help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
12条评论
I had this problem too but it turns out there is a piece that connects to the top of the magazine which pushes a button which enables you to pull the second trigger and power it on.(my dad and I had to take apart the whole gun to figure it out lol
完成的
Mine shoots but jams every time
完成的
When you open the hatch on the right of the gun, you have to push it down very hard to lock in place, then it works
完成的
Lewis Conner, thanks, that did it.
完成的
I have a problem with my rival Zeus I have not checked the batteries yet but it does not want to let me pull the trigger does anyone have a fix ?
完成的
显示更多的7条评论
添加一条评论
12个答案
最有帮助的答案
Try re-solderingvthe wire in the battery tray
这个答案有帮助吗?
得分 3
6条评论:
If the trap door near the barrel is open even slightly it will not fire.
完成的
THANK you. I was about to return the %#*@ thing lol
完成的
Yes... the trap door being completely closed was the key! Thank you!!!
完成的
Holy $@$* I was about to return it thank u so much it was the trap door shut it ALLLL the way even when u think it’s closed
完成的
OMG I just bought all new batteries and was about to return it. Wow thank you!
完成的
显示更多的1条评论
添加一条评论
First you look at the orange hatch , the one that opens up. Second that hatch is not fully closed so you need to close it until you here a snap or a click then it should work.
这个答案有帮助吗?
得分 3
2条评论:
It is awesome
完成的
Incredible simple, this was the problem, thanks.
完成的
添加一条评论
Did ya unjam the wheel part? I'd there is a ball in the wheel part it will not fire.
这个答案有帮助吗?
得分 2
2条评论:
I keep on taking it out but it rejams and bearly goes far
完成的
Mine does the same but mine doesn't even shoot
完成的
添加一条评论
On some nerf rival there is a trap to un jammed when the ball is stuck and if this trap is not correctly closed(you should heatd a “clic”) the electric motor doesn’t work. I spent 1 hour disassembling the gun etc… when i realised i was ready to send it back.
hope it’s helpfull.
这个答案有帮助吗?
得分 2
添加一条评论
Did u figure this out?
这个答案有帮助吗?
得分 1
添加一条评论
Ive done all of this and it still doesn’t work.
这个答案有帮助吗?
得分 1
添加一条评论
what do you do when the moderriser on the gun dose not work
这个答案有帮助吗?
得分 1
添加一条评论
This is a common issue. The springs touching the battery pack get compressed and need to be stretched out. It’s a simple operation, remove the battery pack and unscrew each screw. Pop the left side off then pull, baby, pull. On the springs that is.
这个答案有帮助吗?
得分 0
添加一条评论
How to fix nerf gun rifle
这个答案有帮助吗?
得分 0
1条评论:
how do you fix one
完成的
添加一条评论
e
w3=-ero40ynihio-jk-4p5ymnt-35g
这个答案有帮助吗?
得分 0
添加一条评论
When closing the jam clearing hatch/port near the muzzle on the right side, you need to pull the sliding door forcefully until it clicks (there is no indication of this, and the door appears closed, but you have to pull hard until it clicks). That would engage a switch to deactivate a safety feature and connect the power to the pump.
这个答案有帮助吗?
得分 0
添加一条评论
My is not reloading
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 46,330
