跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z5 安卓智能手机于 2015 年 10 月发布。Sony Xperia Z5 配备 5.2 英寸 1080 x 1920 像素显示屏,搭载高通骁龙 810 处理器,辅以 3GB 运行内存和 2300 万像素后置摄像头。
Sim stuck in slot
Sim card stuck in slot deep
Xperia z5
Not on the sim tray
Iv got that out
I didnt know what it was for
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
My sim card is stuck inside Th the phone still, I can't seem to get it out, I é tried everything lol I'm not good at this kinda stuff
由完成的
添加一条评论
4个答案
最有帮助的答案
Last time this happened to me, I stabbed the sim with an exact knife and pulled out slowly. Took a try or two but worked
这个答案有帮助吗?
得分 4
1条评论:
Brother Robert thank u soo much bro. ur comment helped me and i successfully pulled out my sim. JazakALLAH !
由完成的
添加一条评论
If the phone doesn`t have a push/pull configurations, then the sim would`ve stucked inside a tight space. To remove the micro sim, you will need a small piece of metal that can slip into the micro sim slot and then push it outside so that it would go out. Don`t try to press it forward because it will just make it harder to get out. If you don`t want to damage your phone further, simply go to the nearest Sony center which will they will do it for you for a fee of their service.
这个答案有帮助吗?
得分 3
添加一条评论
Mine is stuck as well in th sim port but I've tried a needle, I've tried tapping my phone around but it's still stuck and Sony says that it isn't covered under manufacturing defect so they won't do anything. So I'm stuck with a phone that can't be used as a phone because the tray will only fit halfway in. Is there anything I can do?
这个答案有帮助吗?
得分 1
添加一条评论
This thread was really useful. If you look carefully you will note the there will be some space on the side of the card, as the SD slot is wider. I have successfully used a paper clip to take the SIM card out without much trouble.
>> Push an unwinded paper clip inside on the side of the SIM card and fish it out. <<
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 12,578
