跳转到主内容
Location of power pads
Macbook air with liquid damage, did a board cleaning and device powered back on. Now a couple month later it doesn't power up.
While trying to reset smc I notice there are no change to the charger indicator light. I suspect the power button has failed. I'm looking to jumpstart the macbook air to validate that, and if so, change the keyboard assembly.
I know Macboks usually have a couple power pads that can be bridged to power it up.
Does anyone know where they are?
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
Emmanuel Marti check the attached image for location.
这个答案有帮助吗?
得分 10
7条评论:
Hi!
I have the same problem. I have now located the "debug power button". But does not work to press on them. How do you do it? And why did you put a red circle around the black thing?
完成的
knutegil11 the red circle is from another guide where this image comes from. disregard it. you will need a flat head screwdriver or a paperclip to "bridge" the two contacts in the blue circle. If that does not work, then you are having plenty of other issues with your board.
完成的
Ok, then I guess my Mac is broken for sure... Thank you for answering :)
完成的
Before you get rid of it, track another ultrasonic cleaning with some Branson ec.
完成的
@gigabit87898 why? knutegil11 did not mention anything about water damage or any other damage.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Emmanuel Marti 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 66
总计 23,654
