跳转到主内容
The Power Macintosh G4 is series of personal desktop computers released by Apple in 1999, and sold through 2004. This page is for the M5183 designation.
Can I put any standard modern hard drive into my G4?
Its got the original 40gb which is full, inaccessible and unrepairable. Want to put in 2 new hd's - something bigger for the OS and a much bigger second for storage. I want to reload OS 9 and then eventually Tiger. Will also be adding a SCSI card.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@jamie - please explain the down vote on this question.
完成的
添加一条评论
2个答案
已选择的解决方案
There are 28 machines with the designation of M5183 but all use the same hard drives. Note the size limits!
A. What's the SCSI card for?
B, That drive is a PATA, IDE or Ultra ATA/66
Standard Hard Drive: 18, 36 GB (7200 RPM) Int. HD Interface: Ultra ATA/66 (ATA-5)
Details: Shipped by default with either an 18 GB or 36 GB Ultra2 SCSI drive (and corresponding PCI card).
Can officially support two Ultra ATA/66 hard drives onboard -- drives larger than 128 GB are not supported. It could be configured with up to three Ultra2 SCSI drives at the time of purchase as a build-to-order option.
Power Mac G4 M5183 Hard Drive Replacement
OWC will probably still have compatible drives. I remember that I did use larger drives that I had partitioned to under the 128 MB limit but don't remember if I did the partitions on a later machine. Knowing your specific machine might help.
这个答案有帮助吗?
得分 5
4条评论:
SCSI is for an old scanner. Turns out I was able to erase and reinstall, so far seems to running well. Looks like MacMall has compatible SSHD's too.
完成的
OWC is MacMall
完成的
I know, I just like alliteration. Thank you for your help. This is a great website.
完成的
Krispy Kremes are cool, correct?
完成的
添加一条评论
Modern HDDs are not compatible with your G4, since these days all standard HDDs are fitted with a SATA interface, and the G4 uses the IDE/PATA interface for HDDs and ODDs.
New PATA HDDs (old stock) are still available however, in capacities up to 500GB or so, but I'm not sure if the G4 can handle HDDs larger than 120GB.
If I remember correctly, Apple used IBM/Hitachi HDDs with custom firmware for lower noise, but standard PATA HDDs should work.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Min Enghauser 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 877
