跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone 5S 更换 前置摄像头 需要注意那些问题?
前置摄像头坏了,需要更换,需要注意那些问题?
Front camera is broken, needs to be replaced, what issues need attention?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
拜大神回答,在线等回答,谢谢
完成的
Google translation:
Replace the front camera what issues need attention?
Front camera is broken, needs to be replaced, you need to pay attention to those issues?
Worship the god answered, and answered online, thank you
完成的
添加一条评论
1个答案
已选择的解决方案
You need to make sure first to turn off the phone.
Then unplug the battery.
Then disconnect the screen, and replace the front cam assembly.
Then put back screen, and finally the battery and test.
Here's the link to the replacement guide in case you need it.
But history is important, as in what happened to cause this, if you know? Such as a bad drop, or screen replacement? Or liquid damage? Different approach may be needed in case of the latter.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
hjp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 660
