跳转到主内容
The KitchenAid KSB5CR is a five-speed blender manufactured in 2006 by KitchenAid. It is available in black and chrome color schemes. Repair of this device requires screwdrivers and prying tools.
5 个问题 查看全部
Should the motor produce light?!?
Great guide!
Because the blender makes a "burnt rubber" whenever its run regardless of load, I removed the cover from the base to inspect the fan, motor, and assembly.
Seeing nothing amiss, I cradled the base (inverted) and "pulsed" the blender. For every pulse, there was a flash of bright light. It was white, not orange.
Is this normal? Could this be arcing? That might explain the "burning" smell.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@engineer that will depend on where you've seen the light. It could simply be the the brushes that are arcing. Try to video what you see and post it so we can see what you see.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Engineer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 119
