跳转到主内容
加入维修社区 - 创建账户
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
My LCD screen is not working
I bought a Screen panel kit because I dropped my Iphone 3G and the screen shattered but the LCD was still working fine and I could still touch the screen and use my Apps. Before installing the new screen I took the Iphone apart to see how to do it by following the instructions but when I did that and connected the still broken screen, My LCD screen does not turn on. When I plug it up to charge the screen turns Yellow! and I can still hear the beep noise it makes when you put it to charge
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
make sure you turn the phone off first (hold power button until slide to power off) or you'll burn out the back light and no lcd will work!
这个答案有帮助吗?
得分 2
2条评论:
Thanks but I was able to fix the problem... All i needed to do was to reset my Iphone with the center button and the lock button
完成的
Right! The LCD is not plug-and-play compatible. Your need to restart the phone after connecting it. Hold HOME+POWER Button till it restarts.
完成的
添加一条评论
Hi,
open your iphone again, and disconnect touchscreen cable from the motherboard. Then try to switch on your iphone, and check if there are any changes. Please let me know result.
Thanks.
这个答案有帮助吗?
得分 0
2条评论:
完成的
I had the same problem after replacing the battery. A simple full reset of the phone did this for me. Holding down the HOME+POWER for 10 seconds did the trick. Thanks guys.
完成的
添加一条评论
i have a similar problem my iphone screen looks fine works fine but i press the left side of the phone and it turns white what could be the cost of this
这个答案有帮助吗?
得分 0
1条评论:
Raul, your question appears as an answer to a 1year old question. It would be better if you click on the link on the right side of this page" Ask a Question" and give as much detail as possible. Then the iPhone gurus on here will see that you need some assistance. Good Luck
完成的
添加一条评论
HELP! i tried the POWER+HOME method and the screen still will not light up. i replaced the digi and the screen and now it wont light up. i tried what i saw in your forum but its still not working. what do i need to do? this is the third screen ive put on it and they all will not light up. (Phone was dead/off during the repair)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 6,076
