跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad X220。这是一款于 2011 年 4 月推出的商务笔记本电脑。这款 12.5 英寸的笔记本电脑配置多样,从 2.1GHz Intel Core i3 处理器到高端的 2.7GHz Intel Core i7-2640M 处理器,并配有 Intel 集成显卡。
Why is my touchpad jumpy?
When using my touchpad it will jump all over the screen. I have cleaned it and it is still happening. What could be causing this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi, What OS is installed in your laptop, Win7, 8.1 or 10?
由完成的
添加一条评论
3个答案
已选择的解决方案
You may need to update your mouse settings. You will find this in your control panel, under hardware and sound. You will then go to device manager which is under devices and printers. Another window will pop up and you will right click on mice and other pointing devices. A button will pop up, scan for hardware changes. This will update your mouse to most recent device settings. It may take a moment. If this doesn’t work you may need to slow down the pointer speed on your mouse.
这个答案有帮助吗?
得分 1
添加一条评论
Jittery touchpad causing erratic mouse control is most often caused by poor grounding, especially when the issue comes on suddenly. Over time, the internal buffering (such as a capacitor failure) of power likely starts to fail. Use a buffered power strip and the mouse cursor should behave better.
这个答案有帮助吗?
得分 1
添加一条评论
try reinstalling the windows and check if pad is working okay. If still problem appears after updating the PC in settings>update & security, Then, Go to lenovo official website. download lenovo service bridge and lenovo system update. Let the Lenovo system update app handle the rest. keep your device connected to charge and ensure not to interrupt because your bios will be flashed and updated. Don't select / mark the option Download deferred only in Lenovo update window. after every update, restart will be required several times. every time, manually open the app and check for next update. 3 or 4 software and firmware updates and boom - you problem solved after final restart demanded by pc itself after some time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily Heffernan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 42
总计 11,070
