跳转到主内容
加入维修社区 - 创建账户
便携式 SoundBot 无线音箱。支持长达 12 小时的音乐流媒体播放。包含免提通话、内置麦克风和可充电电池。型号为 SB571-BLK/BLK。
Why is there static noise?
There is a horrible static sound whenever I turn my speaker on. No matter the volume, high or low, I can’t hear the music over the static sound. Do the speakers need replacing, or could something else be causing the unwanted static?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
3条评论
The answer said nothing about hard wired speakers which is where my problem is. That said, since it is an old Sony receiver, and static is in all speakers, is is possible the receiver is to blame or is this a wire problem.
完成的
My hoverboard has been making a static noise since I went into a ditch, on a narrow pathway. I don't get what is the matter , but I need to know asap if the speakers need changing.
完成的
static noise only on set ups that is it for over 3 months
完成的
添加一条评论
5个答案
已选择的解决方案
Hi,
Try connecting the speaker to a music source using a stereo audio cable plugged into the Line In Audio socket of the speaker and the headphone socket of a mobile phone (for example).
If there is no noise, there may be a problem with the Bluetooth connection. Remove any pairing connections stored in the speaker and also the Bluetooth device (e.g. phone) (see previous answer to you with User Guide link) then re-pair with the Bluetooth source and see if it is still noisy.
If it is still noisy, remove the Bluetooth connection 'stored in the speaker and try pairing with a different Bluetooth device, (ensure that the 1st Bluetooth device has the Bluetooth turned off) and see if the noise is still present.
If there is noise when using both the Bluetooth and the stereo cable there is a problem within the speaker. There are a lot of things in a powered speaker which, if faulty, can produce unwanted noise and it would have to be opened so that it could be checked to see what is causing the problem
这个答案有帮助吗?
得分 7
1条评论:
This was super helpful, thank you so much
完成的
添加一条评论
Hi,
Static sound is often caused by connectivity issues to the Wi-Fi. Make sure that the speaker is within proper range to the nearest router, around 100-150 feet. This will ensure a good connection via Bluetooth, and the static sound should dissolve.
这个答案有帮助吗?
得分 2
1条评论:
I tried this, it did not work.
完成的
添加一条评论
Hi,
Static sound may be caused by dirt and/or dust build-up in the device. Use a condensed air-duster to clear away the dirt/dust from inside the speaker.
这个答案有帮助吗?
得分 2
2条评论:
For my sb571 The sound breaks when it is played at high volume what should be done
完成的
Please troubleshooting
完成的
添加一条评论
No its a wire shortage or either your wires in the speaker are damaged
这个答案有帮助吗?
得分 1
1条评论:
It's brand new strait out of the box
完成的
添加一条评论
Hi,
Solved this problem, this is how…
Connected a old Asus mobile charger and humming noise disappeared during charging…this adapter was a 5years old one.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Yana 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 58
总计 88,278
