跳转到主内容
加入维修社区 - 创建账户
iPhone 的首款型号,型号 A1203,提供 4、8 或 16 GB 容量,采用铝合金背壳。维修时需要进行大量的撬开操作,可能还需要用到焊接。此页面旨在帮助用户对 iPhone 2G 进行故障排除、维修及寻求帮助。
Battery life less than expected
My trusty iPhone, just upgraded to iPhone OS 3.1, is losing battery life fast.
I replaced the battery with a new item from iFixit, charged it overnight, and in 6 hours it is down to about 60%.
Is there a way to reset it, especially the energy management (like resetting SMC on a MAC)?
Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Hi, Where did you buy the battery? I've an iPhone 1st generation and I'm lookgin for the battery... Help me!
由完成的 分享
添加一条评论
9个答案
已选择的解决方案
well, I have done 2 things - I
reset the phone settings and
switched off push email
so far the phone seems well behaved. Unfortunately I don't know which one of the 2 has fixed it - but I will switch push email back on once I have established the phone battery lasts as it should.
这个答案有帮助吗?
得分 1
1条评论:
lasted 24 hours with the battery icon still showing full ... the solution is most likey the reset
由完成的 分享
添加一条评论
最有帮助的答案
Just my advice since I have a 16GB 2nd gen. iPhone. When I upgraded to software v.3 it did not last even a day. I found the clue is to turn off all "push" settings in email. Set everything to "manual" and do it everywhere, also in the submenus. That gave me back my battery life at least.
这个答案有帮助吗?
得分 4
1条评论:
cool - I have my .mac email on push, so I will turn this off and observe. will report back.
由完成的 分享
添加一条评论
Have you tried letting the battery run all the way down until the phone shuts off and then charging for several hours/overnight? That seems to be a common calibration procedure with Li-Ion batteries.
Apologies if that's what you meant by "charged it overnight" but I wasn't clear from the question on whether the battery was empty before you charged it. In any case a full discharge/recharge cycle might help.
Good luck!
这个答案有帮助吗?
得分 2
4条评论:
no worries - yes, the old one was run down a few times, but maybe it needs the NEW one to be run down (silly me not really seeing that, I was so happy to actually change the battery, and it is STILL WORKING ;))
由完成的 分享
I'm not sure whether the run-down calibration procedure is really for the benefit of the Li-Ion cells or whether it's to let the charge circuitry become "acquainted" with the characteristics of the new battery. In any case I'll be looking forward to finding out if this helped!
由完成的 分享
well, it did NOT work.
由完成的 分享
Drat!
由完成的 分享
添加一条评论
Location services is a huge battery hog. Try turning it off (Settings > General) for a couple days and look for improvement.
Do you have Bluetooth on? It shouldn't be the problem, but might as well check. Is your phone jailbroken or unlocked? Those may also make a difference.
这个答案有帮助吗?
得分 2
1条评论:
Location services were off ...
由完成的 分享
添加一条评论
thanks - well it is jailbroken, and location services are off.
it used to last 4 to 5 days in the sam elocation, same services on etc, and now it is dead in 10 hours.
I even have disabled some stuff that was on before (internet access through the GSM provider)
that is right - dead after 10 hours after being fully charged, and new battery .... something has to be wrong, but WHAT
这个答案有帮助吗?
得分 0
2条评论:
Voted down because this isn't an answer. You should add details about the question by editing the question or adding a comment there.
由完成的 分享
very hard to comment or edit if you don't have enough reps to do so!
由完成的 分享
添加一条评论
Are you using the device more? 10 hours does seem pretty quick, but I've never had an iPhone that could last more than about 36 with any real usage.
Did the decrease correlate with the update to OS 3? Did you re-pwn the firmware for the upgrade, or just auto-update in iTunes? I've seen some weird things happening with jailbroken 3.0; if you built your own, you might want to consider reinstalling it.
这个答案有帮助吗?
得分 0
1条评论:
thanks - been re jailbroken. My wife's Iphone (bought the same time, updated same time) seem sto worrk better and she if anything is using it more. the 10 hrs is stdby + use = total time!
由完成的 分享
添加一条评论
My iPhone 2g runs out battery empty for 2mins..
这个答案有帮助吗?
得分 0
添加一条评论
May be you installed too many programs on your phone, you need to uninstall some programs.
这个答案有帮助吗?
得分 0
添加一条评论
Apple told users that the battery recording function does not affect the battery life itself, but will take a larger hard disk space. Therefore, the proposed user to connect to the iPhone with the computer, the records transferred to your computer. When the iPhone with your computer is set to sync, this process will be automated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spikey2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 28
总计 5,101
