跳转到主内容
加入维修社区 - 创建账户
发售于2014年春季的一加 One拥有5.5英寸显示屏,运行基于Android的CyanogenMod 12S操作系统。型号为“ONE A0001”。
sim card not detected
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Check if you still have an imei number in the settings (don't post your imei number here).
If you do then most likely the sim card reader pins are damaged. These aren't easy to repair as the sim card slot is soldered to the board. You should take it to a mobile phone repair shop to fix it for you.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Try another SIM see if it's a problem with SIM or phone itself.
Going down the path of fixing the phone itself can be costly and tedious.
这个答案有帮助吗?
得分 1
1条评论:
Yes I would recommend doing this first.
由完成的 分享
添加一条评论
The sim card is working in another phone. I can also see the imei number but it says 'No sim detected'
Also tried different sim card. Same result.
What could be the problem?
What do i do next?
Any way for solving this problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nizarali karedia 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 15
总计 7,426
