跳转到主内容
加入维修社区 - 创建账户
型号 A1625。苹果公司于 2015 年推出的机顶盒修订版,配备 A8 处理器和 2 GB 内存。
Where is the IR sensor?
I'd like to attach an IR emitter to the front of the device, but I can't see where the IR sensor is located. The iFixit teardown doesn't offer any clues.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
5个答案
已选择的解决方案
After some experimentation I found that the sensor is about half an inch to the left of the LED. Attaching my IR-extending emitter at that point led to reliable control of the device.
这个答案有帮助吗?
得分 8
1条评论:
Unlike the gen 3 you can't see a hole even under a bright light, luckily found this thread @toddjonker has it spot on, 0.5" from the LED. Confirmed on the circuit image from the teardown (https://d3nevzfk7ii3be.cloudfront.net/ig...)
由完成的
添加一条评论
最有帮助的答案
Ref, iFixit teardown image;
这个答案有帮助吗?
得分 11
添加一条评论
From my understanding the remote is using Bluetooth not IR as used in the older models.
Jump to Step 10 of the teardown {CSR (Qualcomm) CSR1010 Bluetooth radio}. If you look at Step 4 {Universal Scientific Industrial 339S00045 Wi-Fi module} you'll see the two antenna sockets one is for Bluetooth the other appears to be for WiFi (its possible this custom part is a dual Bluetooth transceiver so one can have two remotes active for game play).
Remember this model uses Siri and has a trackpad & accelerometer built into the remote. IR couldn't carry the data stream bi-directionally unlike Bluetooth.
The bottomline here is you don't need to worry about line of sight issues like you need to with IR. Here you just need to make sure the antenna is not blocked by metal.
这个答案有帮助吗?
得分 3
6条评论:
This didn't answer the question; I did not ask about the remote's emitter. The new appleTV does in fact have an IR sensor as well as BT. I know this for a fact since I've been using the same non-BT Harmony remote as I used with earlier models.
由完成的
As you hadn't expressed fully your direction here I answered the Q with the expectation you were planning on using the Apple remote that comes with the AppleTV not some other remote.
由完成的
Dan, the question was clear. Your answer did not address the question.
由完成的
grassview - Reread my answer where I clearly stated "From my understanding the remote is using Bluetooth not IR as used in the older models." You'll also see Christopher's answer points to the IR sensor.
由完成的
Dan you didn’t answer the question , it’s ok you’re still a good person
由完成的
显示更多的1条评论
添加一条评论
As a sidebar, for anyone with a 5th gen Apple TV 4K, they now appear to have moved the IR receiver to the opposite end of the bezel, so this info is only correct for 4th Gen
这个答案有帮助吗?
得分 3
2条评论:
What does that mean?
由完成的
Start from the top (question), reading the related answers, and the meaning will be clear.
由完成的
添加一条评论
I can now control the volume of my Pioneer MCS-333 HTiB.
My understanding how Apple TV 4Gen learn my Pioneer (PR) remote is:
the box learned from PR;
the box will push the program to control the volume of Pioneer to Siri Remote (SR).
I thought the Apple TV system will learn the IR sequence from PR thru SR.
I had already tried turning off the Apple TV. SR can still pump up the volume or down the volume of my Pioneer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Todd Jonker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 73
总计 65,918
