跳转到主内容
加入维修社区 - 创建账户
三星 Galaxy S5 mini 发布于 2014 年 7 月 28 日,是一款配备 800 万像素后置摄像头、720p 显示屏、指纹扫描仪并具备防水性能的手机。相比其“老大哥”Galaxy S5,它拥有更大的显示屏、更长的电池续航时间以及更新的摄像头。
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
这个答案有帮助吗?
得分 1
2条评论:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
由完成的 分享
πως το διορθωνουμε αυτο το ποβλημα?
由完成的 分享
添加一条评论
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
这个答案有帮助吗?
得分 1
2条评论:
how do i fix this problem?
由完成的 分享
by flashing it with Odin
由完成的 分享
添加一条评论
添加你的答案
tonyknors 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 2,265
