跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Repaired water damaged iPhone is having some problems
i dont know if anyone can help me on here.
iphone 5s water damaged.. i cleaned it properly. it worked but::
1 sucks alot of power (battery draining fast)
2 every 5 seconds of use it gives a warning. " temperature too hot cool down before use"
.. i can touch the motherboard and feel that its on normal temperature not hott..
solutions as per my experience:
battery draining fixed by replacing u2 ic.
any solutions for temperature too hot warning, any ideas where to look on motherboard for this..
thanx in advance..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi remove all the metal brackets, switch the phone on and try to find where the heat is coming from. There should be component that is overheating. If you find it you have to replace it and then phone should work fine.
完成的
添加一条评论
1个答案
已选择的解决方案
First don't repair liquid damaged phones if you can. They're a nightmare and keep coming back for various issues.
Second, try a new battery. A known good battery of great quality or at least different source from the one you have in there if you already replaced it.
If that doesn't fix it, and you still experience fast battery depletion, heat, and still see this message, then you have a short somewhere. This short may be producing heat and activating this temp warning message.
If you see the message without heat, then one of the heat sensing resistors on the board was damaged from the liquid spill.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
brisbane wholesalers 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 79
