Repaired water damaged iPhone is having some problems
i dont know if anyone can help me on here.
iphone 5s water damaged.. i cleaned it properly. it worked but::
1 sucks alot of power (battery draining fast)
2 every 5 seconds of use it gives a warning. " temperature too hot cool down before use"
.. i can touch the motherboard and feel that its on normal temperature not hott..
solutions as per my experience:
battery draining fixed by replacing u2 ic.
any solutions for temperature too hot warning, any ideas where to look on motherboard for this..
thanx in advance..
1条评论
Hi remove all the metal brackets, switch the phone on and try to find where the heat is coming from. There should be component that is overheating. If you find it you have to replace it and then phone should work fine.
由 Mimi 完成的
