跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Exposing traces on 01005 components
Ihave missing caps around the battery terminal that are missing including an inductor.I have tried hot air rework using solder balls and although the heat is there it doesnt stick to pad(which I now think is missing)
how do I expose the trace under these pads,and can a conductive epoxy be used to glue the components back on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
@birdbrain, most likely you can rebuild the traces by using small copper wires. Do not use any epoxy or circuit writer pens. those are very messy and most of the time will not work properly and increase the risk of short circuits. Post some images of your attempts so we can see what you see.
Update (03/05/2016)
That image looks familiar:-) Definitely no to the epoxy. There is no substitute for soldering. As for the tools, this is not a good area for hot air station and solder balls. You will need a soldering station and some source of magnification to work on this. To solder the connector and/or the components you will have to clean the pads and use plenty of flux. The reason why your solder may not stick could be a heat as well as a flux issue. This is not an easy task and I would suggest that you have someone with boardlevel experience do this repair. Check on here and see if there is anyone close to your location.
这个答案有帮助吗?
得分 3
添加一条评论
to expose the traces you can use a needle or a small hobby knife
and yes if the epoxy says it can be used as a replacement for solder just be careful when using it not to spread it everywhere
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
john byrne 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 149
