Why won't my Polaroid SNAP turn on?
After multiple attempts of trying to power on my Polaroid SNAP, it still won't turn on. What gives??
I just restarted it by inserting an earring in the hole in the bottom
这个答案有帮助吗?
Don’t do this. The hole in the bottom is the speaker and you’ll puncture the speaker.
The hole just at the side of the micro USB port is a restart button indeed, no problem in pressing it. Just be careful not to press the wider hole at the side of the SD card which is the speaker and can be punctured as Alex said.
How to fix my polaroid snaptouch if i left it not charging for a long time? Is the battery dead? And when i charge it, it makes a wird soung…
这个答案有帮助吗?
Have you figured out this issue? My camera is doing the same thing!
same here anywone a solution?
I'm having the same issue found a solution?
@memossita u found a solution?
Dropped it in water, now it makes a sound when it's plugged in. Not lighting up. View screen in back not coming on. Help
If you did left it out without using it, It is probably just on sleep mode. Try turning it on and back off for it to work. It that does not work maybe it just died and you will need to charge the battery.
这个答案有帮助吗?
Also, please refer to the "Camera Will Not Turn On" section of the Polaroid SNAP Troubleshooting page if you are having any more difficulty.
Thanks, this helped a ton! I was so scared cause the reset button wasn’t working.. then I had some thoughts to try to fix it myself... but no! I listened, and it worked!! Thanks a lot!
This is the third polaroid snap touched I ordered that has not worked
My polaroid snap was not turning on either. I figured out that the problem was that a little plastic piece under the pop up visor was stuck. Touch it with your finger, try to release it and the camera will turn on.
Good luck!
这个答案有帮助吗?
What do you mean?
I don’t undersand, what do you do with the visor?
it said it is fulley charged but won’t turn on
这个答案有帮助吗?
i found out why mine didn’t work. it would be duly charged and then the battery would just drop to nothing in literally 2 seconds it’s because my polaroid was from costco. and in costco they have their electronics out on display and constantly plugged in 24/7 so when i bought it they ran out of polaroid’s so gave me the display stand polaroid. so because it was plugged in all the time, the battery’s had been fried from being plugged in for so long
1) Flip the view finder open like normal
2) Inside the view finder cut out, look for the micro switch on the right side. The side toward the timer and shutter button.
3) It’s probably stuck. Use a pen or other small object to flick the power switch on.
这个答案有帮助吗?
i bought the polaroid snap and when i turn it on all the light come on. they stay on but i cant do anything and then it turns off after sitting there for awhile
这个答案有帮助吗?
How did you fix this? All the lights are on, on top and back and isn’t working... help
Hi everyone I havnt used my Polaroid snap touch for a long time but tried using it today after a long time of not being use and it wasn’t turning on. So I started to take it apart and check that it’s reading the right voltage etc as I assumed the battery was dead but the issue turned out to be the ribbon cable coming from the switch where the shutter button is. After removing and reinserting the cable it turned on instantly I hope this helps some ppl.
这个答案有帮助吗?
Do you take any pictures of your steps?
TY
how put out that cable? Any picture please?
I have a Polaroid snap touch. On top it has the pop up flash, a power button and the red picture button. When I press the power button the flash pops up but the welcome sound does not turn on and the screen does not turn on sound is not on. I've charged it all night too. Does anyone have any suggestions?
这个答案有帮助吗?
Did you manage to fix this as am having the same problem
I have the same issue, I just press the power button and when it doesn’t turn on leave the pop up flash up, and find a needle or thin pen or sharp pencil and press the reset button. But I’m yet to find out if doing this removes your pictures
where is the reset button
I tried all of these suggestions except the last one and non have worked what do I do know???!!!
这个答案有帮助吗?
can not get mine to turn on whatsoever its been charging for two weeks and nothing
what a bad investment !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
这个答案有帮助吗?
I took mine back as it was faulty and got a new one and not had a single problem with this one
I'm having the same issue. I just received this today from my daughter as a mother day gift and it won't come on. When it's charging its making some noise. There is no indication that it's charging what so ever.
@Michelle Kimble U found how to solve it?
I haven’t used my Polaroid in, what? A year? I got it for Christmas and used it nonstop. Then it died. So I left it forever. Today, I turned it on, took a few pictures, then put it to charge. Now at Eight, it won’t turn on, but makes sound when I try to turn it on. The sound is the sound that it makes when it turns off, and it was really weird… any answers?
这个答案有帮助吗?
Have you found how to solve it?
Anyone any ideas why my daughters won’t turn on? No lights or nothing when charging? Bought this as a Xmas gift
这个答案有帮助吗?
My sons is doing the same thing. I cant get it to turn on whatsoever!
Try pushing the viewfinder to the left when it pops up.
There is a power on button that ‘should’ be activated when the viewfinder pops up, but sometimes there is an issue and so you need to manually push it to the left, and it ‘should’ turn on.
这个答案有帮助吗?
Happened to me! I thought my Polaroid Snapshot was broken.
Then with a toothpick I did this: there is a small hole next to the charger input to the left. I inserted the toothpick there and it turned on instantly!
这个答案有帮助吗?
The same thing happened to me. It would not turn on at all. My Viewfinder would not pop up and when I charged it a red light would turn on and then it would turn white but still nothing. I tried to reset it to with a pin. Nothing worked. I even connected it to my computer and it would not read it to download the new firmware. FINALLY I tried to push onto the viewfinder again and tried to see if anything was stuck in there all around the edges. I pushed on the edges trying to get it to pop up manually and it worked. The viewfinder popped up and the whole thing lit up. Now it is charging and the 3 red flashing lights are on. My computer also detected it. So you may need to manually get the viewfinder to pop up since that is what turns it on.
这个答案有帮助吗?
This is the third snap touch that I bought none of them wont turn on .Now I have to send this one back to bad camera a waste of time and money , I am a disabled vet I dont need this stress dont they test these cameras
这个答案有帮助吗?
I had this problem, too. What worked for me was:
- I reset the camera by pushing the reset button at the bottom
- I plugged it to the computer while still turned off
- I turned it on while plugged and the MSDC screen appeared.
My computer was able to read it as an USB external device, so
- I deleted all of the photos to free-up its memory
Once unplugged from the computer it turned on finally.
REMEMBER to ALWAYS remove the device safely from the computer, or turn it off before unplugging it.
这个答案有帮助吗?
过去 24 小时: 9
过去 7 天: 60
过去 30 天: 343
总计 54,045
2条评论
Not really answer but did you end up fixing this issue? I am having the same problem and can’t find answers anywhere :(
由 ajm.smith 完成的
did you check on the question that you started? this is a 2 year old question, they are unlikely to return to answer it as they have all been inactive members for some time.
由 pollytintop 完成的
