跳转到主内容
加入维修社区 - 创建账户
Canon Selphy CP910 是一款紧凑型打印机,可以通过 Wi-Fi 连接至相机、电脑和移动设备。它是佳能 Selphy 系列打印机中的第 34 代产品。
Printer still indicate low ink?
After replacing new ink cartridge, the printer still indicate low ink?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 20
3条评论
I had the same issue with my CP1200. The solution was exactly like with the CP910 described here
完成的
Just confirmed that this also applies to the Selphy CP1200 which Martin Merz previously confirmed...
The exact same gear in the exact same location..
When that little gear started to move over, pictures were starting to print out with some yellowing on the right side. This would slowly progress to the middle of the print.
Once that yellowing hit the middle of the print, then the printer would no longer detect a replacement print cartridge.
One little note to mention: When attempting this fix, slide that little gear only part way back, just a smidgen back. Use a very small dab of superglue on the very tip of a toothpick to just apply a miniscule amount of Super Glue to the shaft.. Then slide the gear back over the Super Glue all the way back to it's original position. This way you won't accidentally super glue gears to each other..
完成的
This worked for me for awhile, but then the low ink message started coming back. I opened it back up thinking the gear slipped again, but it was still secured in place with the glue. I ended up scraping the printer and getting a newer model. Hopefully won’t have this issue in the future.
完成的
添加一条评论
11个答案
已选择的解决方案
there is a little gear which can get out from it place in time. Check its position and if its moved - use a glue to hold it at place.
here is an example of wrong position of the gear:
If you can't figure out where is the gear in a printer - look at the bottom right corner of the picture:
If you need a replacement part:
  • google tne next text "pinion gear 10T 0.3M bore 1.5mm";
  • also spare parts for RC helicopters can be applied, for example MH-BP031015
这个答案有帮助吗?
得分 27
35条评论:
You are a genius. Thanks a million!! Zach
完成的
Thanks! My wife now thinks I can fix anything. Made my day.
完成的
Thanks Alexander! That was it!
完成的
how do you get to the gear?
完成的
Thanks for that
完成的
显示更多的30条评论
添加一条评论
I solved this problem but printer stiil give the same message. Any ideea?
Many thanks!
这个答案有帮助吗?
得分 1
添加一条评论
这个答案有帮助吗?
得分 1
添加一条评论
Hey! I tried it on some older models (CP760 and 2x CP780). They also have this problem. Moving gear into place fixed it
这个答案有帮助吗?
得分 1
2条评论:
Hi, quick question, what is the teeth count on CP760, because my was disintegrated. Thanks
完成的
I just checked it the gear has 10 teeth on the CP760. Now I'm going to check if this will fix my issue as well :-)
完成的
添加一条评论
Someone abandoned their CP910 because of the gear failure. I ended up getting it so I could try fixing it.
I initially slipped the gear back into place but didn't have super glue handy, so I just used it and it worked for about 8 prints before having problems again. I had superglue this time, and made sure the gear was very secure. Did 6 prints in a row and they all printed great.
There is a Youtube video that shows how to do this, but I've since realized that unlike the video, it's better to undo the three screws holding the main print engine assembly and remove it from the enclosure first after disconnecting the 2-pin fan cable. It's easier to work that way.
这个答案有帮助吗?
得分 1
添加一条评论
Done! The gear was still there but it was almost totally off the shaft. I applied a small dab of Gorilla glue in the gear and pressed it back on. And now I have a printer again!
这个答案有帮助吗?
得分 0
添加一条评论
Awesome! Stuck some gaffa tape to the metal on the far side - good for now!
这个答案有帮助吗?
得分 0
1条评论:
Thanks so much. You are a genius. It’s working well now
完成的
添加一条评论
Thank you! Worked for me as well for a newer model CP-1200 !
这个答案有帮助吗?
得分 0
添加一条评论
Amazing, and it works. To Canon's credit the opening and access to the printer's innards is easy and commendably simple. It is a shame that their engineers did not think to put the same thread lock paste they used for the screws securing the mechanism to the enclosure. Many thanks for giving a 12 year-old CP910 a new lease of life!
这个答案有帮助吗?
得分 0
1条评论:
How do you get to the innards ??
完成的
添加一条评论
Just one quick comment regarding CP-800 modells.
There are two different versions of gear existing !
One with 10 tooth, one with 11 tooth. Ensure to pick the right one :)
Don´t know if this is valid also for other versions...
这个答案有帮助吗?
得分 0
添加一条评论
works!!! 100%
thank You
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noorhaili 将永远感激不已
浏览统计数据:
过去 24 小时: 24
过去 7 天: 64
过去 30 天: 331
总计 46,994
