跳转到主内容
加入维修社区 - 创建账户
一款由 Dremel 于 2007 年制造的基础电池供电旋转工具。
What does the blinking light mean?
I noticed that the green light is blinking. Is something wrong with the Dremel?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
What if it never stops blinking??
完成的
添加一条评论
2个答案
已选择的解决方案
Don't worry - The blinking doesn't mean that there is an error. The green LED on the charger indicated that you properly plugged the battery pack into it. While it is charging, it will continue blinking. When charging is complete, the light will stay steady green.
这个答案有帮助吗?
得分 12
7条评论:
Sweet I was wondering the same thing, thank you interwebs.
完成的
Same here..........
完成的
Mine keeps on blinking and when I go to use it, it has no power to operate my Mini Mite
完成的
Mine blinks when I first put the battery in..5 min later its steady green and of course it is NOT charged. Waiting to hear back from Dremel.
完成的
I have two lighs. one steady red and other is flasing green float. what does float mean
完成的
显示更多的2条评论
添加一条评论
7700/708 battery. green light has been "charging" aka "flashing of 18+ hours and battery is dry as a bone, no charge.
This @#%$#@^ 7700 has LESS than 18 hours of use in 4+ years. Battery is stores away from charger (separate rooms). does the battery just die from being lonely?
这个答案有帮助吗?
得分 0
1条评论:
Same issue as @ralph78 and @rroby. Charger LED just keep flashing green. I have two batteries - does the same with both. The flashing seems to be somewhat faster than normal charging indicator. It never goes to steady green (indicating a fully charged battery) and neither battery has any power. I use the dremel infrequently so have always charged a battery before each use. I'm thinking it must be a charger issue rather than a battery problem? Do I need a new charger or have both batteries died?
完成的
添加一条评论
添加你的答案
Kat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 22
过去 30 天: 128
总计 40,952
