跳转到主内容
加入维修社区 - 创建账户
Repair and troubleshooting information for the Suzuki FA50 Moped.
Unit does not start
The unit has been sitting for 6 years. I cleaned carb--has great spark and 60psi compression. Put in Fresh Fuel-Has enough oil, Still does not start--any ideas 1986 Suzuki FA50
Update
Not even a hint of starting. However when the spark plug is removed we get a puff of air/compression from cylinder. Very little gas if any on spark plug no matter how many times you kick start it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
what does it do when you try to start it?
完成的
Do you have a spark?
完成的
添加一条评论
1个答案
最有帮助的答案
Sounds like you have carb problems, or a reed valve problem. First things first, unplug the fuel line and make sure the petcock is working. Next clean the carb, make sure all channels and passages are clean, finally check the reed valve condition.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Paul Allan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,090
