跳转到主内容
A rotary tool by Wen with different speed settings and attachment options.
Why is my device not holding a bit?
I am trying to put a new bit in my rotary tool but it keeps falling off when I try to adjust it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
The device collet nut, end piece, may be broken. It will need to be replaced.
You can check more information here.
这个答案有帮助吗?
得分 5
添加一条评论
最有帮助的答案
Rotary tools use different sized bits. Commonly a Tool like a Dremel uses a 1/4" collet size. A dental tool, such as the one I use, a Emesco jack rabbit uses 7/16" bits.
Make sure your bits are the correct size.
https://www.pinterest.com/pin/4602820243...
这个答案有帮助吗?
得分 7
2条评论:
mr.fixit were do you work to know how to fix every thing
完成的
@rozema Cody. I work for myself. Tough employer! Makes me study everyday! Plus I'm old and been many things in my life. stock broker, options specialist, surgical tech, dental lab owner, jewelry store owner, computer programmer, Mac Repair Store owner, saint and sinner. pastor and general PITA to many. If I don't know the answer I go find it, I do the work and try to be the best I can be at what ever I attempt. Now I give it away to help others.
完成的
添加一条评论
添加你的答案
Sergio Palacio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 1,638
