跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for GE Microwave ovens.
Why does Sensor panal malfunction
Panel resets all the time it comes up with close door and select food setting after unplugging unit from a.c. I can reset clock and get it to work once then the panal will revert back to close door and then ask to select food type 1-6. What needs to be done
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
edroberts43 you said that "after unplugging unit from a.c." does that mean you unplug it after using it? I am a bit confused by that. What model is your MW?
完成的
After the microwave malfunctions iIunplug the unit and I then plug it back in and am able to reset the panel my microwave is a G E s/n JVM172QP1WW
完成的
After you plug it back in then you get the error? Or do you get it after you set the time etc. and run it once? Have you consider that it is a faulty door switch?
完成的
添加一条评论
1个答案
Maybe falty power cord.
这个答案有帮助吗?
得分 0
2条评论:
@wesly how would a faulty power cord cause this error?
完成的
I don't understand how a faulty cord would make it not work or reset or nothing works
完成的
添加一条评论
添加你的答案
edroberts43 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 1,192
